4 SALE : 2013 OEM HID Headlights
Tituslloydpullo
How hard is it to install the factory hids in my 2012?
All plug and play?
What if I want an amber led ring around the hid that works with the running lights? Any solder or splicing?
Also, for the sake of reliability, should I skip the extra led ring? Have many failed??
Raptor Retrofit
Raptor Retrofit
HID Specialist
NY
All that's required is a conversion harness so they will work on your 2012. Its very easy to install, you run power to the battery, ground each side and plug into the lights. Feel free to email if your interested or have any other questions - [email protected]
All plug and play?
BAJASVT
SE Michigan
I have a 2014 w/ the OEM HID headlights. If I wanted to install a retrofit w/ the EvoX-R projector and 50w bulb/ballast, could this be made 100% plug and play to the OEM wiring harness?
Raptor Retrofit
Raptor Retrofit
HID Specialist
NY
Yes, we can make the harness for you if you would like. We take a standard H13 harness and change the input to a 4 pin to match the 2013 oem hid trucks.
Raptor Retrofit
Raptor Retrofit
HID Specialist
NY
Would the ballast install in the OEM location or would it need to be mounted elsewhere?
You would mount the ballast separately. If you would like to send the lights in we can do the entire conversion for you.
rocknink
Genesee, CO
Hey Dawson. What's the best way to get ahold of you to get some headlights made up? Sent an email but was wondering if there was a better way to go about it. Thanks
B
Raptor Retrofit
Raptor Retrofit
HID Specialist
NY
B
Did we get back to you yet? Please feel free to PM your email.
