4.5" Light Cannon & Hood Mount Package Special!!
Deleted member 12951
Guest
CrownOffroad
San Diego, CA
Yeah but not sure about cutting into my head liner just yet. Wondering if there is an option that can be removed later. Thinking something that can use velcro and be in the center console?
While our switch panel can be mounted anywhere, it does look good overhead. But as mentioned, once you cut up your headliner, it's a bit difficult to put that back to stock. Plenty of places and room to mount it in the center console but not sure how Velcro would hold up if you're doing any serious off-roading.
AlternativeOffroad
AlternativeOffroad
Los Angeles, CA
Want to buy but out of Aux switches until I add more....
You can always get the kit and wire it in however you please ;)
Crown Offroad also offers an overhead switch panel
---------- Post added at 04:16 PM ---------- Previous post was at 04:15 PM ----------
Just kidding I'm late to the game
jondle
San Diego
Pretty sure you were looking for a more creative solution, but in the short term you could wire a couple lights to the same switch. Switch 1 and 2 handle enough amps you probably wouldn't need a relay to run LED lights, but it certainly wouldn't hurt.
Guest
SW1 = Three 12" Whelens and actuator motor
SW2 = 30" and 40" Blackhawk behind grill
I am pretty close on each one and always like some breathing room.
FireLT
Bracket install completed... driver side went on like butter... passenger side sucked, but wasn't impossible.
Open hood, then prop it up past full.. this will keep hood mount plate against the holes.
Put bracket on top and re insert bolts.
Repeat on the other side... start back bolt first.... tape around area to protect paint...
AlternativeOffroad
AlternativeOffroad
Los Angeles, CA
Thanks for the feedback, appreciate your business and enjoy!!!
