Waiting for a weekend off from work when it isn't 100 freaking degrees outside so I can install them.
Is this deal still active?
So the supplied wiring doesn't really work with the raptor? Doesn't look like it will reach without cutting the wire and splicing it.
We usually just splice the VisionX harness that's included. You won't need the relay, fuse holder, or switch. Just cut the black and red wires as far as possible (closest to the relay as possible) on both ends from the Deutsch connectors, and run them into a single wire to your upfitter wire, and obviously do the same for the grounds. If you have splices (butt connectors) you'll be good. No need for any other wire as you can use the wire in the VisionX harness and toss the rest!
