38/39" Tires
taquitos
Seattle
I'm picking up the tires today and waiting for the wheels to arrive. Is there a way to reprogram the speedo on a 2024. BTW I have the stock 37 package suspension which comes with the same duel live valve shocks as the R. I want to keep this as is with some trimming and a leveling kit. The wheels are a zero offset so maybe some spacers.
It all works with dual live valve shocks. So it could be installed to increase wheel clearance at full compression. You can reprogram the speedometer to pretty much anything. Just need to know wheel circumference and convert that number to a hex code then update with forscan.
Rob O
PNW
"Some say add a better top hat like RPG / SDI top hats are very close to stock ..."
Think you might have that backward: RPG offer 'no lift' or +1" top hats while SDi are 1.75" of lift. Plus RPG seem to take eleventy weeks to ship parts. I have SDi in my truck and it netted about 1.5" over stock (with stock coils). Probably need to run top hats and longer coils for proper 38/39 clearance.
QCRappy
Charlotte, NC
I don't. I mentioned RPG top hat for my truck as I have eibach springs front and rear and to "improve" a weak factory top hat. I also mentioned SDI in lieu of springs up front for the ride closer to stock but it would level up to run bigger tires.
Rob O
PNW
Gotcha ... must have been semantics.
