37" Tire Regrets?
Tyler_GTS
37’s and 3” RPG collars.
No rear suspension mods?
Wondering how little you can get away with if you run the BFG “37”....which is only about 36.5”.
Mine is a 2019 so I think the front end is even a little higher.
500mag
Georgia
Hey 500mag, your truck looks great! Looks like you have KM3's and maybe a lift? Could you share your tire size & lift info? Did you put the 37's on before the lift...if so did you have any rubbing? Finally, do you have any idea of the actual diameter of your tires?
I just put the KM3 315/70-17's on my Raptor & they look tiny! I'm slightly pissed because BFG states they should measure 34.4" diameter...same as the stock KO2'S but these things measured only 33.7" unweighted. My stock KO2 spare even measures 34.5".
Thanks!
Sent from my SM-N960U using Tapatalk
You won't be disappointed with the KM3s - they are great in everything I've tried them in - dry, wet, sand, mud. No snow or ice yet.
Tyler_GTS
Im also thinking about the KM3....how's the road noise? I'm not a huge off roader, but I like the look of the KM3 as opposed to all of the other MT's.
Plus they are undersized, so a 37" may fit easier.
Alford78
Thank you. Yes, 37" KM3s with zero rubbing. As the above poster said, they are 36.5. I have a 2.5 inch leveling kit (polyurethane disc) up front and a 1" block in back. I've had no problems so far, even off-road. I don't race or jump, but I do off-road it in the hunting fields. I had it on Carolina Beach last weekend, and those tires are amazing in the sand.
Can you link the disk and block you are using for leveling kit please?
Alford78
Don’t use a “disk”! Just get a set of eibach springs for around 200.
I’m just curious as to what he’s using. I have Fox 3.0s that I’m either going to use with MT kit or sell them and go with SVC kit that requires 2.5s.
