I was a little shocked too. The stockers must be in the 33 range when mounted. That's Reaper territory.
A little off topic, but, I have been told the 37" BFG projects will fit with no issues on mid perch... their measurement from the BFG website is in the 36" range too.....
so are the 37" projects 34 3/4" as well????![]()
Looking at my 37 BFG's compared to other 37x12.50s on mounted wheels off a vehicle, the one noticeable difference is the width. The tread pattern of the BFG AT design looks narrow(is narrow) when compared to other brands. The Baja looks like it has a wider contact area.
True... I think it's the tread that fills out the width more on the projects while the all terrains taper in a bit more.
Happy to help! If I were to keep the stock liner, I'd pull it out and cut/hammer the pinch seam. Then just use some sheet metal screws to make the liner sit flush on the firewall.
