Blind1
Damn, is Swoop back? I haven't seen that many quotes in long, long time....
You could try going into a race shop and talking to the builders and tire guys there...they have friends and connections who can get you BFGs for a good price without the brick and mortar price tag. But if not, like the others said there are the store bought ones.
JB, I wonder if that is the trend for that brand of fender? Or were you the exception?
vanilla_gorilla said:Eh, the flare isn't that bad, and if you really want to make it look "pretty" you could run a piece of plastic or rubber, attached to the flare to hide the little gap. My truck is not here to win any beauty contests and function > form in my book. Plus, once you mount these tires, you will love the look. Bigg50 was even taken back by how good they look on these trucks in person. You gotta put some skin in the game to play.![]()
If you read Bigg50 build thread, and I happen to wheel with him up here in NorCal, he hit a nice bump, tucked the tires and shoved his fender up, cracking it. By trimming the "hidden piece of the fender, you remove that tire to fender contact point. Again, if you do NOT plan on offroading, you don't need to go that extreme, I plan on getting really dirty this spring/summer/fall.
If you have aftermarket wheels this is a must IMO. I believe you can get away with it if you have stock off set wheels. This is because the tires will tuck inside of the fender and not cause damage. E63 has this setup and I'd confirm with him first. Although, he runs 3.0's and the keep the suspension from bottoming out way better than the stock shocks.
Damn right they look good. These tires really look good in a 37!
I've gotta go to mid-perch anyways. I might just remove the coilovers from the truck and reinstall them without the coil springs. This will allow me to cycle the suspension to full compression and see where the tires contact. Which side seems more prone to hitting, so I know which one to try this with?
I'm hoping I can run 37" BFG on the OEM wheels without trimming the flare.
