24 R Violent Bouncing On Launch
OEMPlus Raptor
OEM preferred....
Oxnard CA
Hate to tell you this but this is why I'm a "firm" (no pun intended) believer in leaving trucks as close to oem as possible. Now you or the shop have to go through all of your mods and see what is causing the issue you didn't have. Personally I don't like wasting time going through these sort of things. You got a nice truck already why mess with a good thing. Tint, bedcover, not much needed on this things unless your going to do some serious off-roading.
Damn I sound like my parents, must be getting old...........
Raptor Vet
Virginia
Why would you spend all that money on a near perfect set up and think you could make it better? Why would you ever run 48 pounds of pressure? who ever told you that should change professions. What a waste of money and time....and probably sleep...Is this the first truck you have owned?...suck it up and return to stock. Then get a hair dryer and remove decals/stickers on the side...a worth the effort mod...I'm just saying...no offense but come on
Booth9999
Idyllwild
Dropped the pressure to 35, didn't make a difference. I have it at a dealer operated performance shop running full diagnostics. I will update with their results.
What is the update here? Did they give any information
Yupthatsme
Arkansas
Im not trying to derail the thread but im genuinely curious. Why do these mods if keeping stock shocks im my mind the stock shocks only have so much travel too them and anything going above that would damage the shocks hence the reason very serious offroad trucks have limit straps. So are you actually gaining anything or is it more for your mind dyno and looks?
Agent_Ara
Agent_Ara
Los Angeles
Wobble problem solved. It was the 38” Nitto Ridge Grapplers causing the issue at high speeds. I’m running 37” 13.5 17 Toyo MT’s now. Don’t use NRG’s on the R and I advise against perch collars of any kind on the R. The SDI top hats are the best option for leveling. Thank you to Tim Fisher at Galpin Auto Sports. Lots of diagnostics and going above and beyond for me. Thank you for everyone’s input and advice, much appreciated.
97,027
60,955
penn_2
