24 R Violent Bouncing On Launch
thatJeepguy
GA
Does it do it in 2wd? If not its tire pressure and brake torque vectoring from software or like Nex said, travel issue from collars.
Booth9999
Idyllwild
The shop told me to keep them at 48 for 5k miles. Not sure why. I'll drop them down and see how it goes. I appreciate your help.
That would make me nervous and makes absolutely no sense. Obviously that builder has never actually driven a Raptor, 48 is riding around on rocks. Can you call and ask him why? I run 32 cold tires, feel great at 35 warm.
Booth9999
Idyllwild
Bummer I was hoping that would do it. On a side note I way looking at your pics of the shock buckets and was shocked to see the jagged cuts. So I went out and looked at mine and they are not as bad but still look like my son cut them with a sawsall. Definitely the worst cuts in factory parts I have seen. Why are they so bad, doesn’t look like that complicated of a part?
not50over
arizona
Yea I run my 2020 F250 with Carli dominator and bags at 48-52 psi while towing at the 7500-10,000 lbs range! 32-35psi unloaded. Then up the psi from there for more weight.(38x13.50x18). 48 psi on the Raptor would be rough. All the suspension in the world will not smooth that out. Rubber bricks. Best start point is the tires. My 2 cents. But yea like the other comments. Too much at once. Makes the process of elimination very time consuming.
1BAD454SSv2
HELL I ZONA
Try it in 4 high . 4A is using a clutch in transfercase to engage and disengage as needed. If clutch is slipping rear end may be over powering front axle. My Gen2 When i do boost launches or racing it , 4H only just no turning allowed . 4A if I'm playing or its raining and need to make turns .
