2024 BEADLOCK COMPATABILTY
Subaruski
PNW
Can you take/swap these faux bead lock rings without removing the wheel/tire from the truck?
I'm interested in getting my 2024 37PP rings powder coated.
I bought Gen1 beadlock rings from a forum member here to see if they will work on my
24 37PP rims. Below is a pic of the result. They will function but aesthetically the cutouts are for the 9 hole Gen1 rims.
What I ended up doing is scrapping the idea and keeping the beadlocks for my Gen1 rims. For the 24 37PP rims I ended up powder coating the original beauty rings to match more of the Gen1 ring color and using that since these are on my 2013.
Chewie
Central Texas
Yes you can. Throw a little anti seize on the threads and don’t gorilla torque the screws when you remount them. Here’s the pattern I use.
Antho
Antho
@Chewie Whe you coated these did you have to strip them? I am curious what they would look like stripped. I know my 2018 trim rings i stripped had a etched like texture to them. Wonder if these are the same.
Chewie
Central Texas
@Chewie Whe you coated these did you have to strip them? I am curious what they would look like stripped. I know my 2018 trim rings i stripped had an etched like texture to them. Wonder if these are the same.
@Antho I don’t know, as I dropped the beauty rings at the powder coat shop I go to and got them back done, but I’m sure they blasted them to get them coated.
