2024 BEADLOCK COMPATABILTY
BoostCreep
SoCal
are the proper beadlock rings even out yet? for this and the R wheels?
The rings for the 24R wheels are the same rings as the 17-18 beadlocks and the 21-23 35” beadlocks.
Those rings also work on the 24 37pp wheels but look kinda off because they’re made for a 6 spoke design, and the 24 37 wheels have 7 “spokes”
FordPerf Addict
Ah ok good to know !
FordPerf Addict
are those aftermarket lug nuts? FYI if they are not conical, they are not the correct lug nuts. Conical lugs are necessary for OEM wheels. they dont seat as well as the oem style lugs.
Chewie
Central Texas
For the 37 it’s gotta be gen 1 rings then.
I bought Gen1 beadlock rings from a forum member here to see if they will work on my
24 37PP rims. Below is a pic of the result. They will function but aesthetically the cutouts are for the 9 hole Gen1 rims.
What I ended up doing is scrapping the idea and keeping the beadlocks for my Gen1 rims. For the 24 37PP rims I ended up powder coating the original beauty rings to match more of the Gen1 ring color and using that since these are on my 2013.
FordPerf Addict
Both of those look really good! I may send my rings to get the powder cost removed in order to get a machined look. Just get them stripped completely. Beadloxks look great but suck to maintain and get everything set up. Balanced and mounted.
Too bad these tire shops won’t do it
Antho
Antho
Thanks for trying this! I have been looking for Gen 1 beadlock rings to try on the 24 37. I did find a bronco guy had a set modified at a machine shop. Not sure on cost.
Gen 1 beadlocks with machined beadlock rings
