2021 Roush/Alcon Brake Kit Install Experience on 2020 gen 2
Alysium
California
Ah, I had not confirmed this anywhere, and this is most disappointing!!!!!!
Am I to assume that GEN 2 (mine) and Gen 3 beadlock’s have the same clearance? Or lack there of?
I was leaning towards the wilwood kit because of the price, but after doing some basic fitment check, I went with ebay roush alcons.
based on the kit dimensions, it needed at least 10mm more clearance with the caliper edge and face.
also spoke with wilwood to confirm the dims I used to build and cut the template.
the engineer I spoke with also indirectly stated that the kit was not designed to work with oem 17" wheels.
I'm using 2017 beadlock wheels with beadlock rings on my 2020.
Zeusmotorworks
Zeusmotorworks
Only wheels I would be interested in are some of Methods +25 bead grips. I refuse to do some zero offset or other some shit that could possibly fu<k up my fenders and liners under full compression. However, I have no more confirmation those will work than I did with the Gen 2 OE beadlock ready.
nikhsub1
Los Angeles
You could probably just run a spacer with the OE wheels and the Wilwoods.... the Alcons come with a 7mm spacer.
Zeusmotorworks
Zeusmotorworks
I’m running the Alcons with no spacer. It’s close… I have issue with spacers that are not hub centric, bolt on. Even then it’s a bandaid.
