2021 Raptor Is a Total BUST!!
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
I wouldn’t mind seeing a smaller V8 with twin turbos.
One thing I see thrown around a lot is the parasitic loss with super chargers and that turbos are more efficient.
I have not researched this much, but I would like to see a comparison of the losses associated with both.
That is to say a naturally aspirated engine spinning a turbo that is not plumbed into the intake. Then the same for supercharger.
Basically the engine is either spinning the turbo or the supercharger and a comparison of the losses associated with both.
Turbo's are spooled (spun) by exhaust gases. No parasitic loss. The negative is turbo lag. Superchargers are turned (spun) by the crankshaft. It takes H/P to turn the super charger the result is parasitic loss. The upside is no lag.
GordoJay
Colorado
Yeah, but. Turbos cause higher back pressure in the exhaust because you route the gas through the turbines. With a SC, you just use headers. Turbos are still way more efficient.
GWBush
Houston, Texas
nope. Totally happy with the Gen 3 raptor. Solid upgrade over gen 2. Raptor R is the perfect way to allow little boys with small ***** over compensate by purchasing an over the top attention ***** truck that has very little extra to offer other then looking better on paper, or the 1x every month when you want to blow away someone with a 0-90 pull on the street.
So what color did you order for your R?
Jakenbake
I understand how they are operated, and as @GordoJay pointed out that there would be an increase in back pressure.
My point was it would be nice to be able to quantify the difference between a supercharger and turbo.
Another interesting one would be one big single turbo vs smaller twins.
Dirtypope
Chicago
After looking more and more at Gen 3
I really think they did such a lazy job on the interior and exterior. I mean look at this and look at RAM. If RAM had automatic 4 wheel drive option it wouldn’t be so bad on gas so hopefully they will change that. I think they focused more time on Bronco and with Raptor they just got lazy. Thank god for TRX so Ford made Raptor R
D552E987-4BFE-4D2E-9E4D-FA5FF655FC40.png 4A420434-9836-4083-AF76-BDBAC01D92E7.jpeg
Raptor R
North
Geeze....what does that make Lamborghini, McLaren and Ferrari owners then?
nmp1
NJ
View attachment 161402 View attachment 161403
i dont think its lazy, its just too modern. there is too much blue and it reminds me of the blue interior on the navigator. the ram has more contrast going from black to red as opposed to going from mostly blue to dark gray. the recaro interior on the gen 2 has better contract but it could have been more.
rtmozingo
North Texas
By definition? I'd be careful subscribing to that line of thought. Not by definition
Ugh, you guys are going to make me do some mechanical engineering - and thermo/heat transfer at that. I'm a nuclear engineer by degree and trade, so I may make some small mistakes. Feel free to correct me or refer to better material - but overall, the information here should be correct.
Roughly, our closed system looks like this:
W= Qin - Qout
where
W = work done by engine
Qin = energy put into the system (how much energy is produced directly by combustion)
Qout = energy lost from all sources
I will rewrite the equation as Qtot = W + Qlost for now, as I think it is easier to visualize. You can think of Qtot as the total energy our engine produces - most will power your wheels, but some is lost in the form of hot exhaust (as well as other places)
For the purposes of our scenario, we will assume the engine and system as a whole is EXACTLY the same, excepting that we will add the turbos or supercharger as we see fit.
Let's say our engine produces 600hp. Combustion isn't perfect however and we can't transfer 100% of the energy anyway. Let's say we lose 100hp, making our net result is 500hp. Our equation is then:
Qtot = W + Qlost
600hp = 500hp + 100hp
Of the lost 100hp, where did it go? For simplicity, we'll assume 50hp is lost to driving other systems off the drivebelt, and the other 50hp goes out the exhaust. Our equations:
Qlost = Qexhaust + Qdrivebelt
Qtot = W + Qexhaust + Qdrivebelt
600hp = 500hp + 50hp + 50p
Our efficiency - defined as W/Qtot, is equal to 500/600 = 83.3% (too high to be realistic, but whatever).
Let's add a supercharger - it adds 150 hp to our engine, but is driven off another belt off the engine - a parasitic loss:
Qlost = Qexhaust + Qdrivebelt + Qsupercharger
Qtot = W + Qexhaust + Qdrivebelt + Qsupercharger
I seem to recall a draw of 75hp is a decent number for superchargers. So:
750 = W + 50 + 50 + 75
W = 575hp. We only gained 75hp of work out of the engine. Our efficiency is now 575/750 = 76.6%.
Alright, let's go back to turbos. Turbos use exhaust gas to produce boost. This means some of Qexhaust is actually recovered and added back to the engine as work - not all of it, but some. For our equation we actually subtract it, making Qlost look different:
Qlost = Qexhaust - Qturbo + Qdrivebelt
Let's assume we get 50% efficiency out of the turbo - half is still lost to exhaust, but half works as boost (25 hp each). It gets a lot more complex here in reality, but we'll keep it simple.
Qtot = W + Qlost
Qtot = W + Qexhaust + Qdrivebelt - Qturbo
550 = 500 + 25 + 50 - 25
Our efficiency is now 500/550 = 91%!!!*
To recap, our NA engine was 83%, our supercharged engine was 76.6%, and our turboed engine was 91%. There are much better in depth articles on the subject, but hopefully you see why we say a turbo engine is the most efficient and supercharger is the least efficient. It is also why turbos are now preferred by all manufacturers seeking to improve fuel economy and why superchargers are only used in select performance applications, where the linear boost is helpful. Or, in the case of SRT, that's all they are capable of doing.
*Edit (as I warned) I screwed up the math. as @GordoJay points out, the equation should probably look like this:
where W = Qengine + Qturbo
600 = 525 + 25 + 50
Efficiency = 525/600 = 87.5%
Thanks for the correction.
GordoJay
Colorado
Qtot = W + Qlost
Did you subtract the 25hp twice? Shouldn't the equation be 575=50+50-25?
