2021 Gen 3 Eibach Front Leveling Springs
wweaver
East TN
Anyone knows how much the driving will go down to, 90%?, if we upgrade from 35 to 37 with Eibach 2.2 front and 1.5 rear? I like that responsive power on the stock raptor I don’t want to lose it. As long as I still have that responsive power and I know I can easily pass other vehicles on road, I am good!
Please bear with me, first time truck owner being a little bit of paranoid here…..
My gen 3 37 feels just as fast if not faster as the gen 2 w 35s, stock to stock. The rear end is so much better also, it is so much more planted under hard acceleration.
FmaxTurboSi
So Cal
Just get the truck tuned by @GooseTuned and you’ll be fine.
pnwobrigade
WA
I'd like to see if anyone has just installed the 1in G3 leveling springs and how that rides.
hyrepower
Las Vegas, NV
I just bought some Camburg 1.5 spacers. I didn’t like the idea of the Allen screws holding up all that preload on the spring.
So-Cal-Al-52
I Love Fossil Fuel
San Diego
Curious what amount of lift you get out the Camburg. It seems all brands of collars provide different amounts of lift. The Allen heads hold the perch collar together but the pre load weight is really held by the groove the collar snaps into when you remove the OEM clips. The collar has a groove it seats into. I have not heard of collars failing though.
Remember to save the OEM clips that hold the stock perch, if you ever want to run springs you will nerd the clips back. I learned this the hard way, I didn't get mine back after installing perch collars.
hyrepower
Las Vegas, NV
Yeah, I know this about the Allen heads, it is just an easy fail point to prevent all together with the Camburg setup. That and the Camburg look better and while they are at it they can install the level up bump stop spacers as I’ll be running 37s as well.
pandonsf
Millbrae, CA (SF Bay Area)
so now that they've been available for a bit and some folks are getting them installed. Are people having issues with the live valve recalibration? I saw the one post saying it threw an error when trying to recalibrate and had to go to the dealer?
NEOGARAGE
North Royalton, Ohio
As long as you follow the steps correctly it shouldn’t throw any issues. We recalibrated our gen 3 without issue
