This is a brilliant idea by Ford and is likely to be followed by others in the future. Having a generator on board is a huge plus to work trucks.
Everyone will do it as it comes almost for free with hybrid technology and it so useful. I noticed a lot of confusion about terms earlier in the thread. Technically, a generator produces DC, an alternator produces AC, batteries produce DC and require DC for charging. An inverter takes DC and produces AC. Of course, when marketing and advertising types start writing about it, who knows what sort of hash they'll make, so unless you want to geek out, just focus on the capabilities.
I don't think it's a good idea to leave engines running while camping, let alone sleeping. The exhaust (odors,noise) would bother others and if it is used in an overland condition, that would be a waste of precious fuel. Campers should stick with portable solar panels for charging.It would be nice if idling the engine would also efficiently charge the battery as well as provide immediate power. I woud guess an idling engine will mostly like provide alot more power than you need at any one time, so charging the battery efficiently as possible would be nice.
If such a feature were there, then perhaps campers would actually opt for a less noisy exhaust so that the engine could idle periodically through the night to power things and recharge the battery with waking people up.
Yes, maybe Ford will put dual alternators for starters, 10 minutes is agreeable but overnight is not efficient. I don't think the generator idea is going to be as efficient as our brains are allowing us to think, we will have to see when they come to market. Over time they will probably massage the design and become very efficient.Not against solar panels, I'm just saying that if the truck can idle and charge the battery efficiently, and say it only takes 10 minutes to do, then perhaps that's not a bad option over bring solar panels with you. I would be a cool feature if you can optionally use solar panels to charge the onboard battery, rather than having to bring a second portable battery with you as well.
There should be dual batteries at least to have an onboard generator, why else would Ford charge $1000 for just an invertor and a couple plugs? It will all become clear when we can see this in personYea, this is quite possibly the case. Not an expert on this, but I think the V6 engine will idling is going to produce a lot of watts, and I don't think the majority of watts can be stored in the battery, most will be wasted. Again, not an expert, but you need a rather high voltage line to the battery to charge it over a short period of time.
There should be dual batteries at least to have an onboard generator, why else would Ford charge $1000 for just an invertor and a couple plugs? It will all become clear when we can see this in person![]()
Good questions, was thinking they would keep a normal cheap battery for the normal operations and add a deep cell battery of some sort for continuous draining. On a pick up truck maybe put the extra battery under the box and the other components could be tucked in-between the box side panels. If Ford is reading our ideas and uses them, they should cut us a check.Ford also charges $1000 for bedside decals.
But remember, the non-hybrid version, no battery, also have the option of 2.4KW for $1000. Unless that version does us a battery for this only, but not for use with vehicle propulsion? Don't think so.
Switching gears a bit, a couple questions about equipment location. Currently, battery is under the hood. Will the hybrid still have the battery under the hood, with a second battery located elsewhere? Or is going to be a single battery? Not sure how it's done with hybrids.
The 400W inverter is located under the passenger side back seat. Will the bigger inverters also be there, or will they be located elsewhere?
