2019 Raptor Intel
jzweedyk
Moab/Winter Travel/Summer Travel
My window sticker that I saved a week ago has R in the box. I just checked (build date today) and the boxes have not changed. Before the boxes some of the things have changed. Before it said 9 normal, now it says 4-Rebill. Some of the numbers after that have changed as well.
Raptor911
Ashburn, VA
An example that a window sticker changes:
My build date was Wed., 10/24. The 1st pic below shows the top of my window sticker which 1st appeared on 10/17 and stayed the same for 7 days until this morning. The 2nd image below shows the top of the window sticker as of today. It has def changed. There are other areas on the window sticker that has changed but the ones I am showing are the most obvious ones.
BTW ... my dealership is in NY. I will continue to check it every day and see what else will change. :)
TheTip247
Kansas
At least your build day didnt change, thats what is important. Not sure what all those other boxes mean but Im sure its all internal and for logistics purposes.
cjaspers
Windsor, CO
Hello All,
I was able to pick up a great deal on a 2019 Ford Raptor from a dealer in Iowa, Dewey Ford. I live in Colorado and have family in Missouri so I plan to make a road trip out there to pick up the truck, likely sometime in January. I worked with Nick Williams and met him via the Ford Raptor Gen 2 Forum on Facebook. Super straightforward and a great guy. If anyone needs his contact info let me know.
Huge Kudos to PooponYou for the help.
I am leaning toward performance blue, alcantrara. Will finalize in the next week or two. The rest is fully loaded without bead locks or Ford accessories.
Question for you all, would you recommend a spray in bed liner or go with an aftermarket company?
POOPonYOU
Paramount, Ca
Hello All,
I'm glad the Facebook group worked for you. I saw your post. I opted for not getting it and will get LineX Premium in the bed and wheel wells. I found a place that will do it all for $700. I heard the factory liner doesn't protect the whole tailgate when it's open.
turn-r-us
I also opted for Linex for bed and wheel wells over the factory liner as Linex covers more areas and has lifetime warranty.
I have a call out to Fox to discuss with them adding perch collars (1.5 inches) to get clearance for 35 and leveling the truck. Interested to see if there will be any issues. Will post once I get a reply.
FordPerf Addict
Hello All,
I’m opting for a vortex liner, as I can get that for 425. It’s very similar to the line X except it’s a little more rubbery and less sand gritty then the line X. Also I think ford is overcharging for their liner
