Allan
Also check your battery temperature sensor and mount. Vibration, shock, and poor temperature management can easily cause premature failure.
Where do I check the battery temp sensor?
How would u find that?I suspect there is a parasitic drain gremlin present in your Raptor. Had the same scenario happen to me on a 2016 Lariat. Only after several hours of diligence did the mechanic trace my gremlin to the driver’s side power door lock switch. I was aware of another F-150 with the same issue. Hope you find this information helpful. Good Luck!
Can this be done through froscan or just scan tool.Possibly the BMS was not reset properly when the battery was replaced initially.
– Battery Replacement
• If the vehicle battery is replaced, it is very important to perform the BMS Reset using a
diagnostic scan tool.
• If the battery monitoring system reset is not carried out, it holds the old battery parameters and time in service counter in memory and it tells the system the battery is in an aged state and may limit the Electrical Energy Management system functions
• NOTE: DO NOT reset the battery monitoring system using the diagnostic scan tool if the battery is not being replaced. This reset is reserved for new battery installation. Resetting the battery monitoring system will clear the learned battery data, the battery time in service, and will affect the aging algorithm parameters, which have been learned since the installation of the battery.
That will only help tell if you have a 'fro, jerry curl etc.Can this be done through froscan or just scan tool.
