2019 - NOT LEVEL W/ EIBACHS
GordoJay
Colorado
Really !! Wow, now there's an idea !!!
I was joking, but there's some truth there. You could lift the back to add some rake, but then there would be parking situations that accented the rake and you probably wouldn't be happy. The problem is that the springs are soft and they're going to flex when the parking spot isn't level. Another solution would be to stiffen the springs to decrease the sensitivity to slope. This would ruin the ride and the off road performance. It might be better to park on level ground. :)
Ron Lanza
Newnan, GA
There is a block kit that Allows 0.5", 1.0" and 1.5" of Lift for Raptors back end. I don't see how a 1/2" could make much ride difference, do you ?
ProRYDE 3-in-1 Adjustable Rear Lift Block Kit
I can get it from American Trucks for $169.00
GordoJay
Colorado
That might work, and it's cheap. If it was me, I'd put on Deavers, but I hate the way the stock 2" block on the rear axle makes the back end hop around on bumps. With an additional 1/2" block in the back, there will still be situations where the front is 1" higher than the rear, those same spots where it's now 1 1/2" higher. If you're OK with those things, a 1/2" additional in the back will help.
Ron Lanza
Newnan, GA
So Would you go higher, like 1" instead of 1/2" ??
GordoJay
Colorado
I would, but I like a bit of rake. I also like to load 1200 pounds of gear and people in it and go camping and I want it to be level when it's fully loaded, so what I would do and what you might do could be very different ...
