2019 - NOT LEVEL W/ EIBACHS
BALLYWOOD007
BALLYWOOD007
Canada
-12 offset is going to poke out way past the fenders and look odd on a Raptor. As long as you do not plan to Offroad, it will work, but do not post any pics of 20” wheels with that offset or this site will give you a rash of $&*^
Better than the -24 offset. The poke is very minimal and it looks aggressive. I like it.
I respect your opinion, however, i purchaed the Raptor for my own self and not to appease others. I've seen raptors slammed to the ground....which looks....terrible. but...to each their own.
usurper
Pittsburgh, PA
What does the height of the quarter and fender liners have to do with level? I think it's a bad assumption to assume that if these two distances are equal, the floor of the truck is "level".
GordoJay
Colorado
Level is a cosmetic issue. Fenders are cosmetic. Therefore it's appropriate to measure to the top of the wheel wells.
TXRaptor
I never stated my opinion, as I am neutral on the topic of wheels poking out too far. The “ration” of %$*^ will come from others, not me.
FordTechOne
Detroit
Did you have the Live Valve ride height reset procedure performed by the dealer? It is required any time a suspension change is made, even if you’re just replacing factory components.
BALLYWOOD007
BALLYWOOD007
Canada
I'm not sure. I hope so. I also found it odd that they went back to original specs to align the truck after adjusting the ride height. I was told that unless they were specifically told what aligment to run, that they go with default. I have been told that eibach has their own specs that they suggest when installing the springs?
Thanks for all your help boys!
Bryantbjb
Salem Oregon
I had the same alignment issue, except mine pulled to the left. Still does a bit which drives me crazy. Here are the Eibach alignment specs from my understanding.
Ron Lanza
Newnan, GA
My scab with eibachs is level within 1 few 8’s when I park on level ground. And can be as much as 1.5” high in the front when not on level ground ?? So what’s the solution ? Even with Devers +3 wouldn’t it still depend on how level the ground you’re parked on is. Here’s my truck at the place I had my front springs installed. Looks pretty close to level here...2033AB1B-8803-48D1-811F-077899D70461.jpeg
