2019+ Fox 3.0 Live Valve Shocks!
CR Gittere
Charlotte
For anyone asking if these fit on 17-18’s or gen 1’s 1the answer is yes. just put these on my 18 instead of waiting weeks for a rebuild. All you need is to purchase the live valve delete kit.
Uh the live valve 3.0 shocks will bolt up yes, buy they will not work correctly and if you have an 18 you do not need the live valve delete kit.... LOL there is nothing to delete, in the 18 truck, as they do not have the electronics to run the shocks. If you bolted these up to your truck I am not sure why.... You should have purchased the standard 3.0 shocks you would have better performance...
nikhsub1
Los Angeles
I think he meant that he put on OEM live valve shocks from a 2019 or 2020 and used RPGs live valve delete on the shocks which apparently turns them into regular shocks like the '17 and '18
CR Gittere
Charlotte
Yes thats probably what he meant and the live valve delete from RPG plugs into the OBD port to block the electronics on the TRUCK side NOT the shock side..... It does NOTHING for turning the Live Valve shocks into REGULAR shocks.... FOR **** SAKE PEOPLE.... YOU CANNOT USE LIVE VALVE SHOCKS ON A NON LIVE VALVE TRUCK AND HAVE THEM WORK PROPERLY.... There are too many people on this forum that have NO IDEA what they are talking about and should stop giving advice.....
nikhsub1
Los Angeles
Umm, you need to chill the **** out. You don't know what YOU are talking about. RPG makes deletes THAT PLUG INTO EACH SHOCK so '17 and 18' raptors can use '19 & '20 OEM live valve shocks.
https://www.rpgoffroad.com/product/2019-up-raptor-live-valve-delete/
CR Gittere
Charlotte
nikhsub1
Los Angeles
Yes I understand that - by his wording it seems like he is putting OEM live valves but who knows? If he is somehow defeating the live valve on the actual 3.0's, that would be really dumb.
CR Gittere
Charlotte
I assumed based on him chiming into the 3.0 thread he put live valve 3.0 shocks onto a NON live valve truck, then plugged the DID into the module, that I think is the OBD port, but maybe not...
Dadlife
Auburn, Ca
That was my bad. Was on the phone, somehow missed the 3.0 header. Just read live valves. My Apologies
