2019 coil replacement
1BAD454SSv2
HELL I ZONA
Yep I would only get 12000 miles on my 14 tremor. I would change plugs every 10000 miles. Getting ready to do set on my 2019 raptor and only at 15000. Boost makes it hard spark to jump gap as your plug opens up especially as cooler air, fall is coming and the air density goes up. Be the cheapest route I was able to do plugs in about 20 min to half hour on my 14. I have top cover pulled of on 19 and looks fairly similar to do the plug change. Stay out of boost till u get them changed.
M
moog5050
Yep I would only get 12000 miles on my 14 tremor. I would change plugs every 10000 miles. Getting ready to do set on my 2019 raptor and only at 15000. Boost makes it hard spark to jump gap as your plug opens up especially as cooler air, fall is coming and the air density goes up. Be the cheapest route I was able to do plugs in about 20 min to half hour. Stay out of boost till u get them changed.
Thanks. What plugs are you running
1BAD454SSv2
HELL I ZONA
I am going to try these . I also have next step colder set . Going to try recommended first. I'm on cobb stage 1 now . Will be going to stage 2 then goose tuned eventually when weather cools down and I can finish installs Garrett intercooler and ams boost tubes.
Nesc204
On my Gen1 I had 1 coil go out on me and the engine went into self protect mode. Vibrated like a jack hammer as it shut down power to the engine and no air conditioning and such. So from my experience on coil packs is it will REALLY RUN like crap when they go bad. Doesn't sound like a Coil problem to me. Sounds more like your tune
sixshooter_45
Arnold
Change your plugs gaps have opened too wide . Set to .28 thousands
No biggie but 28 thousands would be .028
And I agree with post that might be your tune, capture some data and have goosetune take a look at it.
M
moog5050
Doubt it’s the tune since it’s doing it with the oem reflash. Going to change plugs as suggested and see what happens. Thanks all.
1BAD454SSv2
HELL I ZONA
The rutheniums are supposed to last longer than iridiums I have 2 sets of normal heat range and 1 set 1 step colder. Plus 4 sets of ford performance ford gt plugs left over from my 14 tremor.
