2017 no boost
Justin3773
Justin3773
Canada
OK thanks man will definitely check all that. I have the afe cold air intake with that huge cone could the intake still get blocked somehow? I'm gonna check my logs from last week when truck was running good to check wastegate cycles
dillard09
College Station, TX and Socal
Man that sounds so bad.
Who did your tuning? Is he close and can look at it? Or atleast look at some datalogs?
How are you pulling codes? Do you have Forscan?
blwn
Florida
The drivers side wastegate looks open in your picture. Did you say it won't budge or were you able to get it to close and it didn't change anything. I listed to some of your videos, I'd see if you can get someone to rev it for you and try to pinpoint where the noise is coming from
Justin3773
Justin3773
Canada
Hi there it's tuned by unleashed in USA I had 5star before unleashed and liked them way better I'm in Canada. Truck was running so good had trouble getting traction even from a 50mph roll once it was tuned and I had borla put on etc. I will have him check a data log from once it lost boost.
Justin3773
Justin3773
Canada
Yes I did get it to close manually and it did not make a difference. OK will do that the noise is coming from somewhere on driver side it sounds like. I don't think I have a blow turbo it's like a weird sucking air intake sound. Would a small tear in a hose or pipe cause no boost at all ? You were right about the wastegate cycles I pulled up a data log from when it was running good and it shows some numbers. First two are when running perfect next 2 are once no boost started.
Antho
When you are revving are the wastegate arms moving at all? Can you see any other PID than your posting?
Justin3773
Justin3773
Canada
I will Check today are the wastegate arms supposed to move when I Rev the truck up a little? I will do another data log today with more pid's
Donovan
DC
keep us posted. I have had issues lately that are indicative of wastegate issues or clogging somewhere..
