2013 Baja 1000 Carnage
Phyguy
Phyguy
Denver, CO
Yikes, glad you're alright man. For an explanation of why your knuckle broke, look here: http://www.fordraptorforum.com/f9/bending-breaking-steering-knuckle-28639/
Thanks Bird. Yeah I commented on that thread right before I left that I was concerned with my knuckles...with all the abuse inflicted and all. Since I'm back to stock knuckles and I learned a ton about how to weld the knuckle to steel using ni-rod and a stick welder (which I own) I may give a shot hacking some gussets to these until I figure out an engine compartment cage for longer travel up front and a stiffer front end. Who knows. It'll be cheaper at this point and will do the job as I saw this weekend. Thanks again. Great writeup again..
Madcowranch
Genetically Modified
OK
Shit, I coulda fixed that with some baling wire and duct tape.
Glad you're OK buddy. Can you describe what you hit, impact etc?
MotuMute
Dallas, TX
Indeed (from post #23 of that thread):
Awesome job of rescuing that injured rider and his bike :waytogo:
It's unfortunate that ya didn't have time to upgrade before embarking on your Baja adventure. Sooner or later a wrecked front end is in our futures if pushing hard before addressing this issue. Turns out I blew the driver's side IWE and also the rack when I bent both knuckles.
So we upgrade the ridiculously weak stock knuckles - which allows us to take harder hits. Now that the upgraded knuckles don't bend, the next weakest links to give are ___________? I guess we need to stay a step or two ahead...
Biggest
God has lots of pajamas but he does not sleep! How awesome he is! Why worry when you can pray!
Phyguy
Phyguy
Denver, CO
BTW - tentatively scheduled for a cab cage dec or Jan. I'm going to have them stub the rear for a future bed cage and bedsides with some sort of LT in the back.
Here's a pic of the trailside fix. Longer explanation and some Baja stories later when I hit Denver.
Phyguy
Phyguy
Denver, CO
Lower control arm ball joint. Ripped right out. And that sucker is hard to replace but doable with a BFH and another pair of hands.
Phyguy
Phyguy
Denver, CO
Thanks rich. I was going too fast on unknown terrain and hit a washout on the passenger side about 1.5 feet deep. Ripped everything apart. At night.
KaiserM715
Kaiser Söze
More repair pics (courtesy of Locos Mocos):
