2013-2014 Raptors Sync 2 -> Sync 3 Upgrade
EricM
OHIO
Even the non-nav Sync 3 units reuqire the GPS antenna- I assume it is for the time.
Mykee
southern maryland
Ohh, I see. Thanks for the clarification. To be honest, I didn't pay too close of attention to the p/n, I kind of assumed that a unit with the Fakra connector for an antenna would be a nav unit.
When the new antenna comes in I will check the p/n more closely to see which unit that I do have. I ended up with the APIM and screen out of a '17 Escape that I got off of car-part.com for $250, so no big pain if it is a non-nav unit. I just want the clock to work!
Update: I installed the new antenna, and on the clock setup page if I click sync with GPS time will actually change now, but it will only change to 8:46pm, no matter what time it is, and it does not increment. so more troubleshooting to follow.
Mykee
southern maryland
Well, for some odd reason that I will resolve, eventually, nothing comes up on the screen when the navigation button is pushed. It just is a blank screen. But I have got everything else working, by locating and loading the factory as built values based off of my VIN. Although this has changed the appearance of the user interface, which I may leave alone or fiddle with if I decide I dont like it.
My truck is a 2014, with heated and cooled seats, nav, Sirius, sunroof, bla bla bla. The as built values for it if it helps anyone else out are as follows:
7D0-01-01 A221 9001 E20F
7D0-01-02 0401 4210 0233
7D0-02-01 5553 0503 008A
7D0-02-02 0200 0000 00DD
7D0-02-03 0000 DC
7D0-03-01 1F52 3403 0083
7D0-04-01 0103 0200 00E2
7D0-04-02 0001 DE
BoostinChick
West Chester, PA
7D0-02-03 0000 DC
7D0-04-02 0001 DE
Comparing what you have to others your values are different. From the APIM Google Sheet your values look to be for a Lariat FX4. I would flip back to page 11 and 12 where @rkneeshaw posted his APIM configuration. I cross-referenced what he had with the Google Sheet and another forum post with someone who also has a fully loaded 2014 Raptor and they are identical. You also only posted up to block 4 where there are 7 blocks total that need some tweaking.
For example, in your 7D0-01-02 you have 0401:
0 = Ford (correct)
4 = NAV for Sync2 (incorrect - should be A for USB enabled + NAV)
0 = Transmission type (not the correct value this should be 8 for Auto and non-SSV)
1 = Door Keypad and Ambient Lighting
So, the values for 7D0-01-02 should be 0A89 0050 0AC7
HTH sorts out your issue. I am about to dive into this myself.
Here is the Google sheet I am referring to: https://docs.google.com/spreadsheet...VSlDFGFHnfeuhb3RTMVz95730/edit#gid=1479139836
cgibs89
Northern IL
So I did this upgrade the past week, found a guy selling a non-nav Mustang version for $899 and eBay had the 15% off, up to $100 off. Got the whole setup, adapters, dongles, GPS antenna, and VIN coded for $799.
Plugged everything in and didn't change any of the as-built data (I'm assuming that's what they mean when they need your VIN, to pre-load the as-built data from Ford) and everything on my truck works (besides front camera and I couldn't care less). The only issue is the Sync voice over is in another language and I don't know how/where to change it (it's also on version 2.0).
Only changes I've made thus far are the ACM/APIM for aftermarket audio since I've got a Rockford Fosgate DSR1 into a 4 channel for speakers and a mono for my sub. I HIGHLY, HIGHLY recommend this set up as it negates the Sony amp, maintains all your voice over functionality, and allows a proper line-level source (after the ACM changes) as well as remote turn on into your amps. Highs and lows I never knew existed come out crystal clear and the mids don't muddy everything up once I spent the time getting the EQ setup. I used AudioTools app to do that and while it's not competition level by any means, it's WORLDS better than the Sony garbage.
jgwoody
What exactly did you change in ACM/APIM for aftermarket audio?
cgibs89
Northern IL
The main changes are in 727-01-01 and 727-01-02 of the ACM, and 7D0-01-01 in the APIM. Here's the FORScan google doc everyone uses: https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=338817466
I'd have to check my exact settings but I turned basically everything off. Tweeter detection, Center Channel, ANC, AUX1 is a sub/AUX2 is disabled, everything. I've got component front speakers which are a 2-way but the woofers are in the door and the tweeters are in the A-pillar but run off the same driver in the door. So the settings have to pretend it's a normal speaker versus whatever Ford does with the Sony setup and each speaker being it's own independent thing. Rears are just a typical 6x8 2-way.
Fronts: https://www.amazon.com/gp/product/B00BGRMD4C/?tag=fordraptorforum-20
Rears: https://www.amazon.com/gp/product/B01MATSCQ9/?tag=fordraptorforum-20
Remember, the above settings are because I pulled the Sony amp out. If you still have the Sony amp, I'm not sure what this would all do as it would possibly turn speakers off/mess with the Sync voice over.
jgwoody
I'd have to check my exact settings but I turned basically everything off. Tweeter detection, Center Channel, ANC, AUX1 is a sub/AUX2 is disabled, everything. I've got component front speakers which are a 2-way but the woofers are in the door and the tweeters are in the A-pillar but run off the same driver in the door. So the settings have to pretend it's a normal speaker versus whatever Ford does with the Sony setup and each speakers being it's own independent thing. Rears are just a typical 6x8 2-way.
Thanks for the reply. I actually used that same spreadsheet, which says its for 2015-2019 models, and my sound DOES sound better. I was just wondering if there was a spreadsheet with values specifically for our GEN 1's. These values seem to work though.
