UPDATE IT WORKS !!!!! FRONT CAMERA AND INFOTAINMENT.COM SYNC3 INSTALL.
I'm really surprised nobody has experimented with this....Anyhow....I've tested this MANY MANY times and Front Camera Works
Installed - Sync3 by Infotainment.com (programmed to my vin)
Installed - NavTV MyTouch VIM13 F-Cam kit (from my Sync 2 install)
All installed and
-Front Camera FORCED ON works
-Rear Camera FORCED ON works
-Motion Bypass works
What you have to do is this
-Make sure the Truck is in DRIVE and STOPPED
-Double tap the Motion Bypass (defrost button) so it is engaged
-Double tap Rear Defrost (force on rear camera)
-go to the steering wheel buttons to engage Front Camera
-Double tap Rear Defrost button to toggle between Front Camera and Rear Camera
***attempting to Force On the camera "OnTheGo" doesn't work for some reason but from a Stopped Position and Shifter in DRIVE it will work. The FRONT Camera will STAY ON no matter what speed you go to ...you just have to engage it in the Stopped Position with the shifter in Drive.
THERE YOU GO ....and IT WORKS !!!!!!!
i have a 2013 SCREW Sync2 by the way....
Sync3 is a great Upgrade to do....The functionality is seamless without any of the Sync2 problems.
I will try to post photos right now
