Anyone know of a good LED bulb, that will fit these projectors.
In projectors, you'd be fine - beam pattern still has cut-off... However, Noah said he's installed some and removed some due to weak output compared to the HID bulb.
Gonna try a set from here.. They are 15% off, total with shipping $169
D3S - Philips X-tremeVision 42403XVC1 5000k Bulb | 42403XVC1 xenon | Philips 5000k D3S
Perhaps I can shed some "light" on this subject since I have seen every possible bulb/projector upgrade for the OEM HID lights.
The OEM HID bulb is - Osram 35w D3S 66340HBI (4150K). D3S bulbs are mercury free which in the HID world means its pretty much like walking around with a crutch because its "eco friendly"
There are several replacement D3S bulbs, expect to pay $200+ for a real D3S bulb, anything you see on ebay in the $60 range is a fake or complete garbage. There are tons of knock off bulbs out there.
Because these are mercury free bulbs replacing the OEM bulb with a "higher quality" bulb will only gain a few hundred lumen at best. Also most these bulbs are higher kelvin (6000K), when you increase kelvin rating a result is the lumen level drops. So in short you can get a "whiter" light output but the brightness will barely change.
If you do want to go down this road here are the real deal bulbs that you want. Having seen all these bulbs in action I can honestly say its not worth that much money to just replace the bulbs. All you will get is a whiter light.
Philips - D3S: Philips 42403 WX Ultinon
Osram - Osram 66340 5000K D3S CBI: Osram's Eco-Friendly combination where Mercury-Free technology meets lighting perfection.
We can get these bulbs if anyone wants them.
