2013-2014 OEM HID Headlight Upgrade
Jimbo
Mad Frog Mattis
IL
Anyone know of a good LED bulb, that will fit these projectors. :hidesbehindsofa:
In projectors, you'd be fine - beam pattern still has cut-off... However, Noah said he's installed some and removed some due to weak output compared to the HID bulb.
TheJoker
N. E. Massachusetts
I think I'll stick with my 50watt Evo-X HID's from RaptorRetrofit. This D3S bulb does sound like a good option for those not willing to go full blown retrofit though.
Jimbo
Mad Frog Mattis
IL
Maybe only put one in and give us some comparison shots.
Raptor Retrofit
HID Specialist
NY
Perhaps I can shed some "light" on this subject since I have seen every possible bulb/projector upgrade for the OEM HID lights.
The OEM HID bulb is - Osram 35w D3S 66340HBI (4150K). D3S bulbs are mercury free which in the HID world means its pretty much like walking around with a crutch because its "eco friendly"
There are several replacement D3S bulbs, expect to pay $200+ for a real D3S bulb, anything you see on ebay in the $60 range is a fake or complete garbage. There are tons of knock off bulbs out there.
Because these are mercury free bulbs replacing the OEM bulb with a "higher quality" bulb will only gain a few hundred lumen at best. Also most these bulbs are higher kelvin (6000K), when you increase kelvin rating a result is the lumen level drops. So in short you can get a "whiter" light output but the brightness will barely change.
If you do want to go down this road here are the real deal bulbs that you want. Having seen all these bulbs in action I can honestly say its not worth that much money to just replace the bulbs. All you will get is a whiter light.
Philips - D3S: Philips 42403 WX Ultinon
Osram - Osram 66340 5000K D3S CBI: Osram's Eco-Friendly combination where Mercury-Free technology meets lighting perfection.
We can get these bulbs if anyone wants them.
If you want an actual performance upgrade you can send us your OEM HID headlights for the EvoX 50w upgrade. We replace the OEM projector with the EvoX projector which has much wider low beams and more concentrated high beams for further distance. The bulb type switches to D2S and we use 5500K bulbs for a nice pure white light which we power with 50w ballasts for a total 2400 lumen gain.
Theres a bunch of guys here with the EvoX upgrade, ask any of them and they will tell you its a HUGE improvement.
Just for reference here's a few pics of the OEM setup and the EvoX setup.
If anyone is interested in pricing or has questions please email me at - [email protected]
OEM Low beam -
EvoX Low beam -
OEM High Beam -
EvoX High Beam -
HAP
NE NC
RR, thanks for that professional review of those bulbs. You answered all of my questions for sure. Still waiting to see if there will ever be a housing mounted 50W ballast...
Thanks,
HAP
Humvee21
Humvee21
I was looking at the specs comparing the Ultinon bulbs you linked and the Xtreme Vision bulbs. It seems the Xtreme Vision bulbs specs are slightly better than the Ultinon. Its color temperature is closer to natural light and the lumen rating is higher as well.
