2013-2014 OEM HID Headlight Upgrade
cwickd
Asheville, NC.
Where there's a will there's a way :) I typically don't have problems with returns. I wouldn't even return them if I could figure out a way to properly mount these without "rigging" them.
TheJoker
N. E. Massachusetts
Thanks it does help. However, that set up does not look as integrated as the 35W ballast. Is that the OEM HID light?
This is a 13-14 HID headlight. The stock ballast is bolted to the bottom, below the Morimoto XB-55 ballast. Any aftermarket set up would need a new ballast.
Humvee21
Humvee21
I just purchased the Phillips xenon D3S and they are generic with no mounting tabs to fit them into the headlights. They cost $240 shipped and are a big let down. Just say no to these bulbs! Now I'm going to attempt to get my money back... So how much for the HID retro fit?
Your profile pic looks like you have the halogen headlights. Are you sure you have the 13-14 OEM HID Headlights?
155mm
Good catch. He posted in another thread that he just purchased a 2012.
SVTanthony
Pine hurst, NC
There are some nice solutions for the F150s that don't have the factory HID lights. I had the same issue and just upgraded the bulbs - worked great at a very reasonable price.
cwickd
Asheville, NC.
I have a '12- just purchased the Led replacement bulbs H13 and should be getting them this afternoon. If they work out, I'll post a before and after. PS- purchased off of amazon where they have a no questions asked return policy and were only $100. Fingers are crossed :)
---------- Post added at 04:31 PM ---------- Previous post was at 04:30 PM ----------
Thank you SVTanthony
cwickd
Asheville, NC.
Just received my LED replacement bulbs- what a difference! Here's a photo showing OEM on the right and LED on the left. Very easy install as well.
Matmanand4
Eagle Mountain Lake, Texas
I have a 14 and seem to have issues with the HID headlights. Has anyone had an issue with the shutters not fully opening with the low beam. Is there any adjustment you can do to the shutters?
