Remoat
If the starter isnt getting a load applied during test it my not be reproduced. I had a starter passed all the autozone tests and still couldnt turn the engine over. I replaced the starter and all good. I believe relay or fuse 27 is fuel pump related. Should def turn over if that was the case. Good luck, this will bring you and your rap closer....
