Audio system brainstorming
mxbrad04
mxbrad04
just wondering if you ever figured out how you want to go with this system.
Sorry for just getting back to you its been a crazy one at work lately.
So where I'm at is I've gone with jl c2's in the back and c3 components in the front. I'm considering what I should do next which is a big fork in the road. Would it be easier to go aftermarket nav HU with steering wheel control interface (not worried about sync) or do complete oem integration with clean sweep and summing device. I'm currently weighing my options... I'm concerned a bit about loosing climate control on the screen and my backup cam as well. I was reading another thread about the factory bt mic issue so that is also a problem as well. Still looking for more information. If you have suggestions I'm all ears. Thanks!
Sent from my HTC One using Tapatalk 4
Nick@ApolloOffroad
Noah, can you explain a little more about what a clean sweep and summing device do? I've always been curious myself and figured why not ask the expert.
Evanscott29
San Diego, CA
I will be reading this thread as well because I think I'd like to upgrade one day but I would like to keep all SYNC functionality as I like all this gucci shit the truck has (yes, even with the glitches).
Maxx2893
Rock and Roll Offroad
Burleson, TX
He can definitely get y'all set up. I saw what he can do in a shop other than his, retain factory MFT head, change everything else. And man did it sound great. Same sound thru entire volume range, just (obviously) louder.
there are different signals going to each speaker from the oem amp. the jl summing device combines them to become a full range signal. so it takes the front tweeter and the front door and the rear doors and combines them internally to give you (for lack of a better word) a full range signal. once this has happened, this signal goes into the cleansweep to eliminate the factory eq curve. try this, go to your truck and turn the radio on. adjust the volume higher and you will notice that once you get past half volume, you start to lose sound frequencies. this is due to the oem system trying to protect the audio equipment in the truck. just about any aftermarket speaker that gets put in, can handle much more than the oem, so you are effectively reducing the output of the system. the cleansweep removes that, so you have a true full range signal going to your aftermarket amp.
---------- Post added at 01:09 PM ---------- Previous post was at 01:05 PM ----------
you can use use the cleansweep, or any other sound processor to retain the oem head unit and still get awesome sound
AZEngineer
Phoenix AZ Area
I posted my in-progress setup in my build thread today. Everything but the sub and sub box are in transit. Im using the cleansweep dsp + summing setup. Ill try to take lots of pics when i do the install.
I just ordered the same from Noah. 8" JL sub in back to replace the Sony sub, JL C2s in back, JL 570s in front, and new AMP, Summing device, and clean sweep.
