GEN 3 Official Aftermarket Wheels Thread
9AND3 Wheels
SLC, UT
Me too, definitely don't have +25 for F150 Raptor, I'd be ordering Bronze + Black Rings if so.
At 9AND3 we can do whatever offset you want, and we can easily do bronze with black rings. If you want +25 we can make it happen. Shoot me an email and I can help. [email protected]
Rob O
PNW
It’s taken more than a year, but I finally found a set of wheels that tick all of my boxes:
FP Forged FP3-SL ... 17x9 +12 fully machined
Will post pics on the truck once these are installed (looking like mid-March)
With install of my FP Forged FP3-SL scheduled for tomorrow, I thought I'd circle back with a quick weigh-in.
TL;DR ... 29.5 lbs*
*with simulated rings installed -- i.e., all hardware -- and center caps
Of note:
  • I weighed this wheel on two different scales
  • I weighed it both while holding it as well as just the wheel on the scale (wasn't sure the latter would work or be totally accurate, but it did/was)
  • While holding it, I weighed myself first of course, cleared the scale to 0.0, then got back on with wheel in hand (did both a "in front of chest" and "over the head")
  • I did two weigh-ins on each scale
  • Prior to weighing anything I used a 10-lb dumbbell to test accuracy of each scale (i.e., get a baseline) ... and both read exactly 10 lbs
  • In every instance -- weighing the wheel holding it or on the scale alone -- it came in at 29.5 lbs
I have not weighed my OE 17-inch bead lock capable wheels. A quick search shows this wheel is pretty much universally reported to be right at 37 lbs. After install of the FP Forged SL-3s, I will weigh my factory 35 setup (BLC wheel + OE 315/70/17 KO2s) and see how it compares to the FP Forged + OE 37s (35x12.5 17 Load Range C KO2s). My factory tires have just under 30k miles (90% highway), so I'll also note remaining tread depth.
FP Forged
Justin
Reno, NV
A few FP updates.
- Polished with or without powder clear is new finish option.
- The NL wheels are in production. I will have a 17x9 +18 Matte Gunmetal and 20x9 Matte Blk coming for stock. We were able to keep a good amount of concave with the +18. Engineering says the 17x9 should come in around 21-22lbs. I’ll weigh them when they’re complete.
- Street Lock and Classic lip wheels are available to order 17x9 or 18x9 +24 and will keep a similar lip depth. The “lug cup” will be more shallow but lip will be similar.
- Shop pay powered by affirm is available to use on your purchase if you don’t want pay the full amount up front.
- Not so new but I don’t think I mentioned it here but 10% off for first responders and military through GovX
Idaho
North Carolina
-km730mx-hatchet-17x8-5-6-et-10-matte-black-a1-png.pngSure it ain’t forged, but KMC has a wheel I’m considering with a +25 offset and is 25.75lbs and a 2650 load rating. The “hatchet”
Squatcho82
USA
A few FP updates.
View attachment 488241View attachment 488242View attachment 488243View attachment 488244View attachment 488246
Any chance the 20x9 +18 will clear the Wilwood TX6R Calipers?
