91Eunos
Couple pics from before the cab removal. One thing that slowed me down is that I couldn’t find my transmission line disconnect tool, and the ones I have for fuel lines are all too small…and far too thick to slide into that narrow gap between the quick connect and the housing.
So I tried the old “cut some shims from a plastic jug” trick:
And they sort of fit down inside the junction, but no matter how much I pushed and pulled, and tried to feed them in with needle-nose pliers I couldn’t get them to slide into the gap far enough to release the locking tabs:
…so I just unbolted the entire connector assembly from the heat sink/junction block…whatever that thing is called that sits right above the steering rack:
