Firestone jacked my Raptor
PTobias
tx
So I've been buying the Firestone lifetime alignment program for pretty much all of my cars for several years, and took my 2018 Raptor in today for tire rotate/balance alignment tweak and state inspection.
first thing odd was that it took all day - ominous music plays
get it back and they could not get it aligned, and told me I need camber and caster kits. Problem is the steering wheel is pointed two lanes left now just to go straight. They tried to tell me it's because my lift kit exceeds factory recommendations.
can someone guide me on the proper caster/camber kits to get so that I can take it to anywhere but firestone
mine is a 2018 super crew no modifications.
Thanks in advance for the guidance
Phil
pastorwug
Santa Maria, CA
You probably can't get a refund, but drive as fast (in a straight line if possible) to a Alignment shop that has mechanics better than your typical High School Dropout.
I've NEVER trusted a Firestone shop, not even with my lawnmower.
wazatataza
miami
I’m guessing these are the ones they are referring to.
But it makes it easier to align, not that’s it’s absolutely necessary. Also hold in your alignment even after rough off roading.
@pastorwug has both eloquently and succinctly captured the consensus and guided you correctly.
RUN, do not walk to the nearest exit.
If you’re rocking an unmodified suspension, you don’t want them working on your truck ever.
GCATX
King Dingaling
Central Texas
Phil
Post up the before/after alignment printout. There's no reason they couldn't at least get it back to what it was before.
96,789
60,751
RCDoug
