GEN3 Forscan
cwh
Denver
For me, personally, I run the DRL with the markers so all of my auxiliary lights are backlit. I think the truck looks goofy with just the amber surrounds on the headlight and not the three markers in the middle. Plus, I like having the rear lights on so people can see me in the daytime when they're running up on me while on their phone and exceeding the speed limit. The more lights, the better.
It allows me to just get in and not have to change the switch to parking lights, and then back to auto when I get out. Just saves a step and I'm that lazy.
But really, it just looks cool and I like it. Why spend the money if I'm not going to use things for their intended purpose?
Right, I get the look your after, but there is no difference than just switching it to the parking light position? You simply just are skipping a step, correct? Otherwise all the backlights on your pods still light up in either switch position?
swoop1156
USA
That is correct.
RaptorJoe331
USA
What brightness percentage do you have your DRL's set at?
swoop1156
USA
I went from 100 to 75 and didn't notice a difference. I went to 60 and noticed a little IIRC. I'd have to guess and say I'm at 75 and I don't have flickering. I can pull my values if you need, and I can post em up.
Probably already have pages back. Dunno.
RaptorJoe331
USA
I just changed mine a few minutes ago to 60% and really didn't notice much of a difference. Not sure if its because the angle of the sun at this time of day or what. Maybe ill kick it up to 75% tomorrow and see if i notice a more significant change
swoop1156
USA
Let us know!
swoop1156
USA
Will the flickering occur right away if the value is set too high?
Based on the last 115 pages, the consensus is yes. Some have it. Some don't. Never know till you try it. Frankly, my truck is under warranty so if a DRL goes out? Pfft, off to the Lincoln dealer it goes. Figure it out later.
RaptorJoe331
USA
Awesome, thanks for the info!
RaptorJoe331
USA
I noticed when I drove into work this morning, in the dark, that the amber lights in the headlights are much brighter. You can actually see the amber light reflecting off of road signs as you drive by them.
I didn’t realize adjusting the DRL brightness would also effect the ambers when the headlights are on too
96,958
60,896
RichardsonDC
