Also, what idea to do such crazy things everyday...but I have some hearing loss due to flying helicopters almost daily since 1990.
The main thing I see will be an upgrade is the screen itself. Also the fact that it'll use the factory mic. I do think the yulu probably integrates smoother with sync than the autotec, but I'm going off comments I've read.What where you gaining coming from the Yulu E10 to the Autotech?
If you're running through a DSP, you should not have any "audio" issues through the head unit as you're only providing a signal (to the DSP)...all your processing should be done by the DSP and the head unit flatlined. My AT's signal runs to the PAC via OEM wiring, then by TOSlink (fiber optic) to the DSP - no issues in sound. Now I will say, when in CARPlay/AA, all the compression is done by the app you are using - or - if you're running the AT, either by Hotspot or wifi (I have mine installed with a SIM card), again, the app is always compressing, so each will sound differently.So I've been using a Yulu E10 Plus the last two years. Just purchased the autotec unit and will be delivered on Tuesday. Over the weekend I read a thread elsewhere that has me concern about the purchase. A few people had their screens die more than once. Also complaints about static sound and other quirks I don't have with the Yulu. Is it truly an upgrade or should I just return it and not bother to try it out? It would run through a dsp, then to my aftermarket amp. Longevity seems to be a problem within the first year which scares me.
