TomDirt
Hesperia CA
LOL no holes in the ceiling. I did put a heavy fiberglass welding blanket over the whole thing the first time, but as you can see from the video, its pretty anticlimactic removing the springs.
That Fox sticker! Little mf'er is just thick enough to catch on the perch collar. Once I cut it up & peeled it back off the shock body, the perch collar was ready to slide. Did No one at FoMoCo or Fox catch that glaring error?
tractorpole
Western WA
I think next time I rebuild my shocks I will just repaint them white and add rancho stickers instead of running fox stickers...
Pyro3601
Lethbridge Alberta Canada
When I was going to mid, my stickers where ******* e d and there was lots of corrosion present already. So before I sent em back for rebuild I just let the bodies and collars soak in a tub of diesel for a day or two and then the little set screw come right out and the collars moved with minimal effort.
818raptor
La
i have a 2 gallon above the spare. i still have a spare in the oem location, plus one in the bed. then theres 2) 2.5 gallon tanks on the passenger side frame and a 3 gallon tank in the bed. gives me lots of air to run the train horn. er....i mean the tire inflator
Can you show/tell me how u mounted that up above the spare
gonna have to text or remind me in a month or so. just had a hip replacement 10 days ago. not crawling under the truck for a while, and by that time will probably forget
rookie. i have mentioned it several times over the past. instead of looking at 25,000 posts in 24,000 shock perch threads. just look through all of my posts. all the answers in one spot
TomDirt
Hesperia CA
Interesting development. I did the live chat with mood asking if the K200366 was the correct part number for our trucks to witch they told me no.
I posted this last year. They definitely fit.
