Zeusmotorworks
Semi-retired, now just a happy grumpy old man!
That work with ours?uh....way too much! Try this:
That’s a Gen 1 EcoBoost oil pump. Raptor is a Gen 2, which has a 2 stage pump.That work with ours?
good to know! ty.That’s a Gen 1 EcoBoost oil pump. Raptor is a Gen 2, which has a 2 stage pump.
Thank you sir... did not think they were compatible.That’s a Gen 1 EcoBoost oil pump. Raptor is a Gen 2, which has a 2 stage pump.
Chain elongation was an issue with early (11-14) Gen 1 engines; there’s a TSB for it, but it can be avoided by running full synthetic and following a 3k-5k mile oil change interval. What concern are you having that you believe the chains are stretched?Awesome write-up! I'm visiting a year later as I prepare to change my stretched chains. Hopefully some knowledgeable individual is still active to answer my question about special repair tools.
In reviewing the service manual procedures, it seems about a dozen special tools are required for this job, mostly to press seals into the front cover. However, your writeup only specifically mentions the camshaft holding tool and the front crank seal tool. Are the others unnecessary where these seals can be pressed in by hand or with a good old hammer/socket combo?
2018 F150 with 2nd Gen 3.5L Ecoboost. Unfortunately not a Raptor: please don't get out your torches, this is one of the best writeups I found for the engine. I'm aware the Raptor engine is high output but from what I gather the timing system is virtually identical.Chain elongation was an issue with early (11-14) Gen 1 engines; there’s a TSB for it, but it can be avoided by running full synthetic and following a 3k-5k mile oil change interval. What concern are you having that you believe the chains are stretched?
Also, I see it’s your first post, what truck do you have? Feel free to introduce yourself in the new members section.
