Installed 37's on Gen3 35 Raptor - no issues.
4x4ready
USA
Lots of speculation / feedback on if 37's would fit. Thought i would share some pics/info on my install.
- Stock truck, no suspension changes.
- No clearance issues, full lock each direction has a minimum of 2" clearance even at closest position to any chassis/fender.
- Full size Ford Forged wheel w/ 37X12.5R17LT fits in stock spare location no modification. I did have to center it as it was raised by moving it about 1/2 back.
- Tires are BFGoodrich 37X12.5R17LT 116S KO's (specs here)
- Ford Forged wheel + stock 35's weight was 103.2 lbs
- Ford Forged wheel + 37's weight was 101.6 lbs.
- Stock offset (34mm) which helps
Other notes:
- Plan is to per-order Fox Race shocks for 37’s
- Picked up some Alcon 5mm spacers but 12.5 wide 37" is narrower so the stock wheels have no clearance issues
Factory 17" Forged Aluminum wheels specs (from @FordTechOne):
- Forged Aluminum (bead lock): +1.3”/34mm
- “Raptor 37” forged aluminum bead lock: +1.2”/30mm
Installed
Closest position on front side
Stojanowski
Temple, TX
Need a profile shot of it... There is a stock 37" wheel and tire package coming for sale around me and trying to decide if I want to do it.
37s on my power wagon looked almost too big
4x4ready
4x4ready
USA
Ill get some here soon but, definitely not to big.
Goode22
alabama
Would also like to see a full profile picture. Any rubbing. How is the ride? Speedos or any other computer issues?
4x4ready
4x4ready
USA
Zero rubbing across entire range with a 2” gap at it’s closest position bumper or chassis.
Going to get on a flex ramp soon and will post more detail.
Ride has a little more cushion which was the point (more sidewall).
No change in feel/power (1.5lbs difference in tires helps)
Very Slight increase in resistance in steering gut goes away when switching from Normal to Comfort.
A tune would be great but not an option yet
37’s look ideal (my preference) - the 35’s for me looked like they had some room for more.
QCRappy
Charlotte, NC
Sick! I would think trying to stuff in some toyo mt 37's without a level may not work. My gen2 is on 9k miles old and local dealership is getting in a 35 package at MSRP. Thinking about it but would want to move over the wheels and tires (only have 4k miles and a matching spare)
4x4ready
4x4ready
USA
From my experience what matters most is wheel offset. The same tire can go from zero rub to major rubbing on wheels alone (personal experience). e.g. I can go 37x13.5 on the stock wheels or rubbing w/ 37x12.5/27 on 0 offset wheels.
I think what's also important is these are not gen2 fenders / wheel wells so things might fit on gen3's that didn't on 2's without modification.
QCRappy
Charlotte, NC
Exactly. It definitely looks like gen3 fenders are much bigger. Haven’t seen a gen 3 in person yet
