isis
PA
Received a package from Rappy Graphics [emoji3] installed the flag will install the B pillars this weekend. They were pretty wrinkled as you can see from the pic I am assuming this will flatten out when I install.
Question. I have read about installing both dry and wet? I am sure wet is easier. Any tip from those who have installed them are appreciated. This is something I hate doing can’t stand bubbles or not lining up perfectly.
Warm and wet. It’s a good rule for quite a few things.
Russ103
MD
Tint is done. 5% on sides, even darker on rear window by applying 5% over factory tinted glass, also put 5% on the sunroof (next best thing since finding a 802A Raptor without a sunroof is next to impossible)
0E15B46A-C96C-4397-B2C7-666D098C24D2.jpeg E417C9AD-45F9-430F-B40B-74D919430E22.jpeg
Also disabled the seatbelt reminder chime
Steve_S
USA
View attachment 138912 View attachment 138913
Tint looks great!
I wanted an 802a without a sunroof as well and couldn’t believe I stumbled upon one at a local dealer. It worked out so well and was meant to be.
alphatwox
North Carolina
Thank you! Just plain water or a mix of anything?
A 95:5 mix of water and dish/hand soap helps.
For small graphics, dry is perfectly fine but with larger ones soap mix gives you a better ability to reposition the graphic without ruining it, aids in removing bubbles, etc.
alphatwox
North Carolina
96,586
60,555
CleverGirl77
