ARE DEAVER LEAF SPRINGS worth it ?
waveslayer
CA
Better? Can you describe how it’s better? I love the stock ride on the street, will it help it in terms of comfort? Or keep the comfort the same?
I don’t doubt that it’s better Offroad, but I don’t want to sacrifice any on road performance and comfort.
Also I’m guessing towing performance improves and there is less sag when towing?
And I see guys reporting wheel hop. I do notice that but could never put it into words until now. Glad I opened this thread and know what it is
It is way better. Truck feels planted on and off road. Go Deavers ! Made me love the truck even more
My wife thinks I only have 3 guns
Nick@ApolloOffroad
Hi. Are you able to add an extra leaf(s) to the existing factory ones? I ask because I Just had Geiser Springs added to the front and now the rear sags by 1”. Goal is to add 37s. The front would still require cutting back the fender to the metal. Also, is there another alternative? Would Collars work on Geisers for more lift along with additional springs in rear?
You can have a custom spec spring setup made by Deaver for the added height you desire or weight that you carry. So if you’re looking for a custom setup, we can definitely coordinate that with you.
The Deavers make the truck feel more planted on road and eliminate wheel hop because they remove the factory 2” rear block which removes another piece from the puzzle.
As far as on road with bumps and expansion joints in the freeway, the rear suspension setup just makes the truck overall more compliant.
Towing performance is sacrificed with adding Deavers. The truck will sag more unless you properly spec the rear for the weight you’re carrying. However, when the truck is unloaded, the springs will be tighter and the ride will be sacrificed.
Let’s talk more about your towing/hauling needs and we can create a setup that will work well for you. Let me know if we can help.
Booth9999
Idyllwild
These are the same ones that Ford used to run Baja so they are as close to factory tuning you can get. Ford was going to run them stock but seems like they decided to save some money and add blocks. One of the best upgrades to buy for the truck if you are going to use it in the dirt.
mezger
Basically what Nick, waveslayer, Booth said. It's pretty noticeable, glad I did the mod.
jaz13
Given all the upgrades to the Raptor elsewhere, I don't think they would cheap out to save a few bucks on the leafsprings. My guess is Ford didn't want to compromise payload and towing any more than they already did. As posted by a vendor above, standard Deavers sag more when towing and HD Deavers result in a harsher ride when unloaded.
brettmess24
No question about it they are worth it!
Don’t listen to the ******** if you tow or carry a load the HD deavers still ride ten times better than stock.
I had +2HD deavers and still do for
Sale.! Went to Icon for the ability to switch up as my truck is always changing and I tow and always carry minimum 300 lbs.
One of the best things you can do to your Raptor is get rid of the flimsy stock leafs, there junk.
Scott Lambert
brettmess24 - regarding the Icon Setup. I’m going to be towing a 8’X20 trailer occasionally. Once, unhooked will the ride be compromised and potentially sag eventually?
Scott Lambert
Scott Lambert
nick@appolo-optics - regarding the I’m going to be towing a 8’X20 trailer occasionally. Once, unhooked will the ride be compromised and potentially sag eventually?
