Rear Springs
BANE
Michigan
Hey Guys
Im in the market for rear springs but dont know witch ones to get. (+1 +2 +3)
Ive done some research but cant decide.
I have Mid Perch With Mud terrains KM2 35''
Im not a street queen and i tow my boat (6000LBS) so what would be the best set up, Im looking for the more level look/stance
Thanks
gbrown27
Auburn, Al
If you tow a good bit i would talk to Cory at RPG about national hd's or call WSI about their progressive leaf pack that is designed for towing
Yukon Joe
Trafford, PA
I'm in the same market. I have the national standard duty, and they have served me well. I have out grown them and need some HDs.
I'm considering both WSI and the Nationals through RPG. From what I'm learning, the WSI pack is pretty strong, meaning you will need weight in your bed when going off road. But towing will be no problem. Also they are probably arched a bit more than the Nationals. Both have good bushings.
If you're just looking for towing capacity, you could go with the add-a-leaf option. This would be your cheapest option.
Lastly, I think sdhq offers bags.
Yukon Joe
Buffalo Run Support Raptor
http://www.fordraptorforum.com/showthread.php?p=364119
pat'sRAPTOR
Everywhere
if you're looking for the level look on mid perch i believe the deaver +2 will give you the look you want. if you're looking to tow talk to RPG they have thier bump stop kit with a longer air bump for towing and you can get their HD nationals with that set up you can tow a ton of shit Jarrett had that same set up on his eco boost at the TRR!
Allied Offroad
Kansas City
Towing Stainless Steel pontoons, on a 20' trailer, with a 37'' tire , 4 ammo cans full of tools, high lift jack, F/E and mount, shovel, LED lightbar, Lightbar rack, roll caged using WSI leaf springs.... Oh and here is a video of us offroading the truck at TRR.
Ford Raptor Jumping, 2013 Texas Raptor Run - YouTube
$1100, shipped (conus)
Tested.
Email us to order
[email protected]
Mviohl311
Thanks Yukon, I think I'm going with the wsi springs I was just nervous that it was going to be a much stiffer ride than stock
