Dmh performance cutouts
6.2
Banned
Canada
Ask the dealer, but as long as it doesn't cause the problem, should be fine for warranty.
GsxrRaptor
GsxrRaptor
Whittier ca
I jst checked with my dealer the service written that I've bin dealing with told me that as long as is behind the cats il be ok with he cut out.
GsxrRaptor
GsxrRaptor
Whittier ca
GsxrRaptor
GsxrRaptor
Whittier ca
I got my bad lanz hpev 3" cut out kit yesterday and installed it right away.
I replaced the resonator with the y pipe.. perfect fit it also gives it alot more volume with the electric cut out closed sounds really good with it open and closed...
i ordered the clamp kit that they offer as well for easy install i ordered 2,
the rocker swtich it comes with i tapped it to the number 4 aux switch so it powers up the switch that the kit comes with ..... cake install if any other questions buzz me be more than happy to assist .... im sure all other kits are similar. and with the cut out is defiantly a head turner
one thing i informed the company that the wires had to be a bout 2 feet longer to install under steering wheel thats were i wanted to place mine but for now i have the switch hidden in the glove box.. ,
ima order the remote control kit they offer ... for a much cleaner look
il post some sound clips later on today...
GsxrRaptor
GsxrRaptor
Whittier ca
yea it can be wired to the aux, thats what i got the power from one of the switches since the switch the kit uses is a rocker switch u have to have two switches ... the aux to power up the switch and the switch from the kit to control the open and close valve its simple... pm me if ya need help wiring it up
Aaron
Meme Corps Commandant
WA
GSXR, you know at first I was going to go with DMH, but after looking, it's $35 cheaper to go with Badlanz and they offer a longer warranty. Thanks for posting about this kit, you definitely saved me some money.
