KaiserM715
Kaiser Söze
I have been getting some rattling from the driver's side door panel. Any sort of rattle or squeak drives me crazy, so I had to fix it. The first trick was to get the switch panel out of the door. I wedged a small screwdriver in between the rubberized cushioning around the arm rest and and the switch panel and pried up and it popped out.
This is what I saw:
![switchpanel01.jpg switchpanel01.jpg](https://www.fordraptorforum.com/data/attachments/171/171994-10730932e1a25229b2d922c38ab7c6cd.jpg)
The rattle was coming from a loose fit between the switch module and the outer plastic sleeve of the panel.
My solution was to wedge some fabric into two pockets of the sleeve (refer to the red arrows below):
![switchpanel02.jpg switchpanel02.jpg](https://www.fordraptorforum.com/data/attachments/171/171995-dc72b84da4161d701960253bc12402b2.jpg)
That seems to have fixed it.
This is what I saw:
