Installing Radiance Adapt 40 light bar (with pictures)
Kurator
Kurator
NYC
If your brackets came scratched or if there is ever an issue with your order, you should always reach out to us right away. Anyone on here will tell you that we will always be responsive and help you in any way possible. We don't ever want anything to be wrong with your order.
Please let us know if there is an issue with your brackets. Send up a couple pictures of the scratches so we can take a look at it, please.
You can text me at (317) 934-6778.
Thanks!
Sidney @ SPV Parts
Nah Sidney, thats totally ok. Scratches are really small and I already Sharpied them over.
John really helped me out with sending over pictures of his customers' installs and guided me over the phone. So I know your support is fire, and I will contact you in case it starts rusting in these areas after a while.
Otherwise its nothing to sweat over... Thanks!
Kurator
Kurator
NYC
Finally done. Some notes: If you want to use just firing triggers via AUX switches, controller needs to be disconnected. Otherwise they do nothing. I connected 2 trigger wires to Aux 2 and Aux 3, just in case I remove controller in the future. Otherwise just 1 wire needs to go to power. I used fuse probe to connect to fuse 36.
Nohowtoplz
Illinois
Hey guys.
I decided to spend some time to install 40 inch Radiance Adapt light bar. Figured all the wires, and I need to run 1 wire through the firewall, to connect relay harness to underdash controller.
For those who done these previously, is passenger side grommet is the easiest choice?
Can I fit said wire through existing grommet to avoid drilling?
Do I need to remove wheel liner or is it optional?
If I use Radiance controller, should I still wire radiance backgroud and flood trigger wires to my aux switches?
Is it ok to leave gps module glued under dash?
Thanks alot for help!
Nice job. Light bar looks awesome. Any issues with the bar partially blocking the camera? Or the adaptive cruise control?
zachery55
Rocklin, CA
Looks great. Any issues with camera view In The front? Considering doing this on my 24 with the modular but want to make sure I won’t have any issues or would be better suited just using a different light bar
