Installing Radiance Adapt 40 light bar (with pictures)
Kurator
NYC
Hey guys.
I decided to spend some time to install 40 inch Radiance Adapt light bar. Figured all the wires, and I need to run 1 wire through the firewall, to connect relay harness to underdash controller.
For those who done these previously, is passenger side grommet is the easiest choice?
Can I fit said wire through existing grommet to avoid drilling?
Do I need to remove wheel liner or is it optional?
If I use Radiance controller, should I still wire radiance backgroud and flood trigger wires to my aux switches?
Is it ok to leave gps module glued under dash?
Thanks alot for help!
Nex
RIP CoronaRaptor
Washington State
On a Gen 2, but should still be the same. On my Switch-Pros I cut the nipple off the big grommet and ran the control wire through that. Behind the fuse box.
And when I ran power for the UHF, I went through a grommet passanger kick panel area. Easier to drop or remove the inner finder.
For the back lighting, I left the 30" attached to the parking lights but ran the 4 LP9s on uplifter switch 5. Didn't want them on all of the time. And with the Switch-Pros doing most of the work I had the extra switch.
Kurator
Kurator
NYC
Hey guys, is this nipple is the grommet I use to run wires?
Kurator
Kurator
NYC
Install so far. Too bad light brackets came scratched from @Specialtyperformanceparts, but I think its not a big deal for me.
Kurator
Kurator
NYC
More pix...
Kurator
Kurator
NYC
Dude, I found out about coronaraptor from your post in this thread (reading your avatar). Thanks for keeping him alive in our forum. ❤️
Kurator
Kurator
NYC
Hopefully this is a grommet?
