VHF radio install pic's
Dutch451
Madison, WI
Not sure what happened with the video. http://youtu.be/SmZ8aU9dpL0
This winter if i have the time i want to get my extra.
Tested today and got my Technician license. Woohoo, now I can finally install all this stuff, lol. Unfortunately my laptop has been out for repair for a bit now, so I wasn't able to study the General material, but the examiner said I could come back within the year and take it and they won't charge me. Hopefully I can find a garage to use so I don't freeze my ass off running wires. I'll get pictures posted once everything is in.
Since I want to mount the face plate in the headliner, hopefully I can come up with a mounting plate that'll work where I can put a couple more switches in it for whatever.
Wilson
Wilson
South Dakota
You can use my garage if you wire mine or just use my garage
All The Way
Lockport, NY
The General test isn't to bad.. The Extra test is gonna be fun.
rkneeshaw
Northern Michigan
Installed my antenna mount today, what a bitch that was. Getting under the carpet and into the console cleanly is a real challenge. But finally, after about 3 hours, I got it in.
Now I need to order a radio :)
And terminate my power and ground
And connect RJ45 jack to the side of the cupholders
DEGBTI
San Diego
going to install my antenna mount friday. Same as yours. Any advice? going to my center console too. thanks
rkneeshaw
Northern Michigan
Be prepared to be patient, and you're going to have to almost entirely dismantle your center console.
I had to remove the passenger seat (at least unbolt it and move it out of the way) so I could get enough slack in the carpet to run the antenna cable accross and up to the back of the console.
From there you'll have to remove the 2 8mm bolts near the bottom rear sides of the console so you can lift the console up about an inch or two, giving you enough room to get that large antenna connector routed up and in.
I chose to run my wiring right under the little media hub inside the console. That way the hole i cut will be really hard to see.
i also intend to use the aux in ports on that little media hub in there to pipe the audio from the radio into the built-in stereo system.
I also ran a small amount of cat5 forward to the front of the cup holders and I intend to put a RJ45 jack there on the side of the cupholders so the mic can plug in there.
Be prepared to bleed too :) my hands are all cut up.
But in the end, it will be real clean and OEM like.
