Truck Stance
Tailgate
canada
I have a Gen 3 2021 37 package Raptor and have noticed that the rear end is 1/2 inch lower than the front end. can anyone tell me if this normal for these trucks? Normally you would be raising the front end to level out the truck.
2020FordRaptor
Nevada
Shouldn't be that way. Should actually have a rake
Bluu
Bozeman, MT
How are you measuing this? From the ground to the bottom of the wheel well?
If you're parked on level ground you should have a ~1.75in rake, where the back of the truck sits slightly higher.
So-Cal-Al-52
I Love Fossil Fuel
San Diego
This does not sound right. You either measured wrong, or you have an issue with the suspension. I have never heard or seen a Raptor sit lower in the rear when all stock. My 37 only had about 1 inch of rake in the front (Lower). then the rear. Some come almost level but what you described does not sound normal.
Can you post a picture of the truck on level ground?
