Sway Bar for the stock LCA: More responsive in corning, better side load control & balance
Joe Durrt
mesa, arizona
Some quick details on why this Sway Bar for the stock LCA is a must have for raptor owners:
• Includes a lower arm rear support kit to help keep the alignment from changing and will strengthen the weak point in the lower arm mounts where they frequently bend with any heavy contact to the front wheel.
• It will improve overall handling by providing you with better side load control and balance on and off-road.
• The stronger sway bar will allow your Raptor to be more responsive in corning while keeping your truck leveled at the same time.
• You will feel a noticeable difference after our kit has been installed
• It is an affordable upgrade that is also the first step in doing mid travel or long travel down the road
• Why is this better than the stock sway bar?
The stock sway bar is not strong enough to correct the lateral loads when driving and will make your suspension feel less balanced in cornering. The Foutz Motorsports front Sway Bar offers more stability for your Raptor and will minimize body roll over the stock sway bar.
• It features a larger .125" diameter bar and optimized sway bar arms so you have the perfect feel with more control and better grip when driving aggressively or just cruising.
• Foutz Motorsports for all gen raptors and they also have a kit that works with the FMI fabricated LCA's too:
Nex
RIP CoronaRaptor
Washington State
Joe Durrt
Joe Durrt
mesa, arizona
They make 2 sway bar kits,
One that works with Stock LCA:
and another that works with the foutz fabricated LCA:
