Opinions on my suspension upgrades
mtnghost
california
So, had the truck checked out and no surprise I need bushings and springs replaced. Speaking to the “Raptor specialists” in my area, and researching and let’s be honest having my own opinions I have come down to what I think I wan to do. I am super new to trucks, but not new to track duty street cars. So I would like all your expert opinions on why or why not my choices are right or wrong for my usage.
Ok here goes, my UCAs are worn, my lower ball joints worn, leaf springs and eyelets worn, steering rack leaks, tie rods worn, and sway bar endlinks worn.
I really like Foutz work and products. I also have real bad ocd and would like to keep the brand mixing to a minimum. Was thinking of keeping the stock LCA for now and replacing the ball joints, what brand rack should I get? Apparently they are NLA new or from ford? Also should I do a aftermarket steering pump kit? What rear springs should I get? Deaver or Icon, I was leaning toward icon due to adjustability and they also make shocks and matching front coilovers if I decide to go that route later. I think that’s all the parts for now, so let’s move on to how I will be using the truck. I primarily want to overland it, and if I am ever lucky enough to get it to a raptor run, it would be nice to feel what this truck was meant to do. Also it’s my daily ATM so don’t want to make it a dedicated off road rig. Thank you all for your input, and no response is wrong and every input will go toward making the best for my decision. Thank you all again for taking the time to help out!
TomDirt
Hesperia CA
I think I paid a little over $100 for newer LCA bushings, another $250 to a reliable shop to rebuild my steering rack, and ended up with RPG's (steel, not billet) UCA's. For now, I'm going with a new (oem) steering pump & reservoir, (and staying with 35's). There's already a steering cooler built into the truck, too. The Lee steering upgrade is $1500 for the Raptor system, and nobody local I'd trust to install it.
TomDirt
Hesperia CA
Sure is bright and shiny, though.
Jhollowell
Everett, wa
@TomDirt where did you see steel UCA's from RPG? I've been wanting a new set but don't want heim joints at the frame so i was looking at Baja Kits or Blitzkrieg.
@mtnghost I would suggest Deavers and stock shocks for your use. The Icons sometimes don't play well with other kits if you decide to do more later and the shocks are regressive which means they are stiffer at the beginning and get softer towards the end of the stroke. That will give you a rough ride on the street and i'm not sure how that works offroad either. Generally you want it softer in the beginning and stiffer as you get deeper in the travel to help with bottom out. Icon knows their stuff so i'm sure it works great, its just weird that all the other shocks do the opposite. Also, i would stay away from the billet UCA's. they look cool but the heims will wear out fast and its super expensive to rebuild them. Keep the bushings at the frame mount.
TomDirt
Hesperia CA
You're right. They are Blitzkrieg, not RPG.
Gumby
Nashville
Just for a simple overland rig I would rebuild the stock LCA. Deaver or icon not sure on that one I have Deaver +2 @mwaite09 has Icon setup in stock hight configuration. not sure witch I like better We both are running Eibach in the front On low. Both trucks are very capable of overlanding.
I have been rebuilding the fox 2.5 my self they are not that difficult to do. and the parts and oil cost around 25-28 bucks a shock. Once you get shader valves in all the ones you own.
TomDirt
Hesperia CA
mtnghost
mtnghost
california
Thank you for the input, I was thinking of just replacing the LCA ball joints with stock for now unless someone gives me a good reason to go aftermarket. I wish I could have the rack rebuilt, as I would like to keep the factory ratios and quality. Also I agree the $1500 for the “upgrade” is a hard pill to swallow. Yikes!
mtnghost
mtnghost
california
I too don’t understand why Icon went digressive! I totally agree off road it’s better to have Cush valving and allow the progressive springs to handle bottom out to a point. Hopefully the valving would have some bottom out protection but also that’s why we have the air or hydro bump stops. As far as UCA, I was looking at the steel ones, don’t know if the material or the design was the worrisome aspect of them? Likely the extra upkeep of the ball joints. I have taken this into consideration and it was one of my main concerns going aftermarket. The shop I went to says it’s a non issue and they 100% go aftermarket on these. It’s part of the reason I posted, as they are a raptor specialized shop and you all are raptor owners that know and care about the platform. Thank you for your feedback, I appreciate the input and also I’m a bit on the fence about changing these parts.
mtnghost
mtnghost
california
These look a lot like the FMI arms with a very similar description. I will check them out, thanks again. For the record, are these what I was warned against getting? Because of helmjoints?
