Roush serpentine belt
Goon
Has anyone found a replacement for this pulley? Roush discontinued it and I’d rather not do the FEAD shield kit at this time.
Part number 116219A216AA
EricM
OHIO
Is it an idler puylley?
Idler pulleys are pretty easy to get- even if you have to get it made custom. Metco or ASP can make you anything you need.
Goon
Yes it should be. Just trying to make sure I get the right size but Roush has been no help with the specs and I can’t seem to find them.
HAP
NE NC
If you don't have the upgraded FORD idler, this is the easiest way to go. I think it was upgraded for the 2014 model. No need for the belt shield either.
R,
HAP
EricM
OHIO
You only need to measure the diameter of the pulley. You also have to know the number of ribs on the belt and wether the idler face is grooved or smooth.
Metco or ASP can get you what you need from that. If it's a 90mm or 100mm diameter, or close to it, Metco should will have something on the shelf that works.
Goon
R,
HAP
Does that change at all with it being supercharged?
HAP
NE NC
Nope. The Roush set up works fine with the upgraded OEM tensioner.
R,
HAP
Goon
This is the pulley I’m looking to replace 9A3FFE81-10A0-4BBC-9FA9-389652F2A869.jpeg
